VP Calais central locking problem
speeny
melton south
vl turbo
I'm having problem find were I hook up aftermarket central locking in my VP Calais it already got it want to hoot.the new one up I can use remote please help to were I put the wires so it work
turmoil117
Donating Member
Armadale
Vs berlina
Wires go in door when button press go 'bwoop bwoop' then work
speeny
melton south
vl turbo
No help there mate its a cheap one of Ebay so I can use.keyless entry I'll that a photo of were the wire go if that would help
turmoil117
Donating Member
Armadale
Vs berlina
Yea mate I was just being a dick.
Try hooking the main door loom from your aftermarket kit onto the actuator in the drivers door
speeny
melton south
vl turbo
2013-05-24 21.30.39.jpg2013-05-24 21.30.39.jpgI don't know were to.put them here's all the info on the wires
turmoil117
Donating Member
Armadale
Vs berlina
Ok put the orange and the orange/black wires straight to the actuator in the drivers door. If you take the doorcard off you should be able to see what colours they are then you can find the wiring where It pokes through the drivers kick panel and attach them there (to save you trying to feed the wiring through to the door). Everything else is straight foreward. Like the brown wires go to the indicators E.T.C.
This should work aslong as all of the doors unlock/lock with the drivers door
DJ_Cosmic_Fire
smarter not harder
South East Queensland
www.house-mixes.com
VP S-Pack Oct '91 - VT SrsII Wagon - VE SV6 SrsII
If you want to upgrade the alarm system etc ,you will need to 1st turn off the factory system with the over-ride Zardi key, put the OEM remotes away and fit the aftermarket system you have & follow the instructions supplied. You can tap into the OEM wiring as above ^_^ but if you're not confident in doing so - then don't do it. Bear in mind with your eBay kit that there are some features like the immobiliser that actually only use a simple relay which bypasses the ECU. IMO this is not a good thing at all, I have a brand new complete Crimefighter cobra system of which is still unopened in the cupboard that I originally purchased for the Pathfinder.
speeny
melton south
vl turbo
How much do u want for it I think it would better putting a hole new one in cause a tx5 turbo I had they ####ed the alarm up and car need to be wire back up
