vp cluster
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by pr0n, Jan 21, 2007.
  1. pr0n
    pr0n It's A Me ' MARIO '
    Gladstone
    03 VY II S V6
    hi, i just replaced my vp calais cluster with a standard vp cluster i have purchased, all the light bulbs are good but when i turn my headlights on it doesnt light up. my old cluster lit up, any ideas. i cant drive at night safely :(
  2. pr0n
    Gladstone
    03 VY II S V6
    anyone??????????
  3. 89vncommy
    89vncommy New Member
    VN Caladore
    Umm .. Have you checked the fuse ... If you plug in your old cluster again does it light up ???
  4. pr0n
    Gladstone
    03 VY II S V6
    ill have a look at the fuse when my dad gets home since he took my car to work today for some unknown reason and left the ****box ford.
    and if the fuse is good ill stick the old cluster in again and see if it works
    reason i changed the cluster was,
    bit that tells u how many km's u done doent work.
    speedo is like 15km out,
    tacho doesnt move unless u rev it to like 3000rpm then it moves like normal.
    fuel guage takes like 15mins before it moved and tempreture was sticky and it went up and down all the time.
    i got a 2nd hand cluster off ebay put it in and i havent had any problems with it accept it wont light up.
  5. SweetWagon
    SweetWagon booosted
    Springwood NSW
    VS Berlina Wagon Supercharged
    check the bulbs in the back maybe, unusual for all of them to blow but, if the fuse is good, you may have to use a mulimeter to test the illumination wire that switches with your parking lights.
  6. Burt_vn
    Burt_vn Back in the game
    Gold Coast
    VG V8 5spd, 400hp 5spd soarer, vq stato
    yea check your fuses, there are actually two fuses for the instrument cluster illumination. I had the same problem, didnt notice the i think its number 7 fuse, is also for the instrument illumination, was just a little 5A fuse. So yeah check your fuses, and make sure both are ok.
  7. pr0n
    Gladstone
    03 VY II S V6
    them 2 fuses u told me were in good nick, although while i was at it i checked every fuse and fuse no1 was blown. i replaced it and well my cluster lights up now.
  8. Burt_vn
    Gold Coast
    Yeah i beleive fuse no1 and fuse no7 are the cluster illumination fuses, although no1 controls a few other things. Glad i could help :thumbsup:
