vp commodore hard starting
madsav
your ass
your ass
i have a vp v6 commodore 1992 auto,when you driving around the temp gauge sky rockets, and its very hard to start,
any ideas on what might be the problem?
madsav
your ass
your ass
if anyone has any thoughts of what the problem is or how to fix it , would be very thank ful
JD
Donating Member
Deep South, SA
www.ccgm.au.tt
1.6L Turbo Holden Croooooooooooze
I had a 93 vp exec with similar problem it turned out to be stuffed radiator does your leak a bit of coolant as well?
Stevob
54
May 1991 VN Wagon V6 Auto
It's the Crank Angle Sensor. Mine does the same thing. I'm not 100% sure but I think the harmonic balancer needs to be removed to replace it.
1vngal
North Tassie
'Ruby' 1991 VN Exec & '98 Proton M21 Coupe
Yes, with VN series II motor onwards, the harmonic balancer does need to be removed to get to the CAS. It's a relatively easy job to do, providing you have a gear puller or something similar to remove the harmonic balancer.
potshots007
37
Mildura
VN series II custom :) and VZ exec
what i did to check mine is drive around till its warm, then stop and turn the car off, try start it and it doesnt, then i got out with a spray bottle and cooled the crank angle sensor then tried again and it started, also i had to take my harmonic balancer off to get to my crank angle sensor and i have a series 1
90VN55
33
stanthorpe, qld
90 VN SS 5speed, '90 VN Calais 5speed
u have to remove the harmonic balancer to get to the cas. but i didnt need a gear puller to get mine off it just slipped off
