VP Dash Equipment
I
ir8prim8
Guest
My odomiter and my trip meeter have stoped clocking over and my fule and rtemp gages are always reading incorectily or not reading without a thump.
is it possible to fix all the equitment so it reads right and works.
can u buy new equiptment for it and also get a tako for it.
all help is greatly apreciated
stocky
34
i take it you have a level 1 cluster? the dash with just fuel speedo and temp?
i would suggest just buying a level 2 cluster for less than $50. this will give you a tacho and should fic your problems. having to thump the dash is a common problem and i think the only way to fix it is to do something to the voltage regulator inside the cluster.
if you want to go an extra step, get a level 3 cluster from a calais
I
ir8prim8
Guest
ye it would be the lvl1 cluster (as u put it)
where exactily do i go to get them form? can i buy them online? can i install them my self? is there any modifacations needed? if i can install it my self how hrd would u rate it form piss easy(1) to hard as all F*#@!(10) to do?
stocky
34
what dash do you want to install, the level 2, or the level 3 calais dash? level 2 will just go straight in, but level 3 will require modifying the wiring, and im not sure how to do that on a VP. look around the wreckers for those clusters
I
ir8prim8
Guest
thanks again i will do that
is it hard to ghet into the dash to install them or is it just a fiew pices here and there to get to it ?
