VP Elec Windows, module Qs
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by STEALTHY™, Feb 7, 2007.
  1. STEALTHY™
    STEALTHY™ So Wet For You!
    SA - The Roadworks State
    Just wondering if anyone knows much about the power windows module (under the steering column one)
    My VP has only front power windows, however the looms are there too the back doors, just wondering if the modules are the same weather 2 windows or 4 windows.
    Also want to know, if the switches from the fronts, (same as utes) can be used in the rears doors once i get the motors.
  2. markovr
    markovr Well-Known Member
    northside brisbane
    07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
    Yep modules are exactly the same as all that the module is used for is the power for the rears that times out after 45 seconds after you switch the engine off and you open the doors as you probabaly know.The switches are the same too and can be used for the rear doors.
  3. STEALTHY™
    thanks for that matey.
    Although i just checked the switche, and there pretty dodgy anyway, so i guess i might aswell get all 4 switches anyway.
    Also forgot to add, if i unplug the switches it has now (just fronts) and put the switches with 2 buttons in each just go straight in? and will the child lock work?
