vp police dash question
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by ringfeder3, Sep 6, 2018.
  1. ringfeder3
    ringfeder3 Active Member
    Nsw
    2017 colorado, 96 vs v8 ute, suzuki gsx1400
    I understand that bt 1 speedometer needles are not illuminated in the normal way and I understand why this option was included.
    Bt 1 vps which I drove back in the day had a constant source of illumination from above the speedo.
    When I bought mine, I had no dedicated bulb shining on the speedo, which as far as I recall, was unique to the bt 1.
    I pulled the gauge cluster out and there appears to be a small angular bracket (factory) fitted to the top of the cluster but there is no socket or wiring.
    My question is, if I wanted to wire up this as a light, where would I wire it to? I recall they were consistently illuminated.
    Being a bt 1, I am surprised the wiring isnt there ....
  2. h8tensv6
    h8tensv6 Active Member
    Newcastle NSW
    2009 SV6 2002 VX 1989 VN 5 Litre
    Maybe previous owner after the cops disconnected it. The wiring and the plug could be down behind the cluster just hanging or been cut off.
  3. ringfeder3
    Nsw
  4. ringfeder3
    Nsw
    This is the bracket....
  5. ringfeder3
    Nsw
    doesnt appear to be any wiring behind the dash...
  6. ringfeder3
    Nsw
    Ok... here is what I have pieced together:
    There should be a socket fitted to the angled bracket (as pictured). From this there are supposed to run two wires (one +ve, one -ve) down to two of the three terminal located behind the tacho on the rear of the gauge cluster.
    Now I need to know:
    1. What type of socket was used in the bracket? I have test fitted several 'standard' Commodore ones without success. And...
    2. Which 2 of the 3 terminals are positive and negative?
    Advice appreciated...
  7. ringfeder3
    Nsw
  8. ringfeder3
    Nsw
    The three terminals can be seen running diagonally from top to bottom on the right of the photo...
  9. ringfeder3
    Nsw
    Solved I believe. Good information from Humphrey Instruments in Wollongong. Old mate has put together a bulb and loom with fitting instructions for $18... Remembered them from the old days!
    Commo Baba likes this.
  10. Brettly-2008
    Brettly-2008 Active Member
    Bunbury
    WM Statesman - VE SS Commodore
    What's the reason for the downward illumination (as well as back-lighting) for the police cluster? I remember EA and EB used a down light and back-lighting back in the same era and I though it was a bit dated compared to VN-VP's crisp green design.
  11. ringfeder3
    Nsw
    So they could be driven at night without lights but still have an illuminated speedo. Sometimes a stealthy response to a job is necessary...
  12. Brettly-2008
    Bunbury
    That makes sense.
  13. Lacksballs
    Lacksballs Active Member
    VK Group C Replica
    Now there is just speed cameras! You just get the bill in the post.
