VP sounds to REV HIGH
I
ir8prim8
Guest
My 95 VP revs high all the time and i strugule to get 300km to a tank. a bloke at work thinks that the someone might have changed the computer chip in it.
if it has been chipped how do i tell and if it hasent how do i fix the econmey and the high reving.:confused:
all help is greatly apreciated
stocky
95 VP? so is it a VR/S or VP?
just take out the memcal i guess, and see if it has any different labels on it
253@7k
300rwhp supra. yay.
TT Supra/HZ Ute.
Sounds like a tuning thing mate. Time for a service maybe.
I
ir8prim8
Guest
Sorry Bud typoed its a 92" my bad
and it has only just had a service...
Please Explane
stocky
remove your left hand side kick panel. your ECU is behind that. unplug it and remove the two screws. using a socket tool, remove the two screws on each side of it. remove the metal cover and you will see youre memcal. if there is no label or anything on the blue memcal, try removing the blue cover and see if there is any label on the chips.
sircruisealotVS
South Brisbane
VZ LS1 Calais
you say it revs high...how so?...at idle what does it rev at once the revs stablise? when on a highway doing say 100k's/hr what does it rev at?
when did it start revving too high?
it could be as simple at the throttle cable being too tight.....
jules
we like the bun
pimpin
is the transmission slipping or shifting late?
anton1o
[GMHVN6]
37
West Subs,Melbourne
VN 6 Berlina '90
Id go with them, See what rev's your getting at Idle,60kmh,100kmh then we can determine something happening..
Shortstuff
Random
2016 Golf GTI PP
I'd agree with that^^^. Having a car chipped can't make it rev higher than it did before at a certain speed. Is it auto or manual?
I
ir8prim8
Guest
The car is an Auto..
the car is booked in for a service in the next couple weeks and i realy need to know wat to the the mechanic what to look at for me.
The car mainly revs high when the car changes gear.(even whilst going easy on the gas). Compairing my car to most others i have been in it dose not rev higher than them whilst doing 60 or 100.(dosent have a tacko(the reason why i said sounds))
one thing i did notice was that on occation when the car ghanged gear there is a slip of power to the wheels. and the car shrugs when it puts it into the next gear.
