Vp spac 1992
Keri
Beaudesert
VP COMMODORE SPAC
Ok I have a vp spac I've had it on road for nearly 6months & just recently it's been hard to start no spark to coil pack replaced crank sensor replaced coil packs replaced ignition relay check engine light is appearing from time to time. Wen I bought the car had to replace ignition barrel both front door locks & boot lock. Security is turned in off position. Other then the pcm ignition module I am stumped to what the problem is CAN Anyone pls help me :/
losh1971
North Tas
VE Series I SS Ute
DFI by the sound of it.
losh1971
North Tas
VE Series I SS Ute
The ignition module under the coil pack. We are talking V6, aren't we?
Keri
Beaudesert
VP COMMODORE SPAC
Yes v6, And I didn't know that's where the ignition module was located..... I would of assumed it was somewhere else....
Keri
Beaudesert
VP COMMODORE SPAC
No spark, coming\ going to coil pack...
losh1971
North Tas
VE Series I SS Ute
Make sure you smear it with heat sink paste when you fit the new one.
Keri
Beaudesert
VP COMMODORE SPAC
The ignition Module ?
losh1971
North Tas
VE Series I SS Ute
Yeah
losh1971
North Tas
VE Series I SS Ute
When you replace the DFi make sure you buy a Delphi. Cheaper ones have a habit of failing prematurely.
