markovr
- Nov 23, 2003
- 3,075
- 252
- 83
- Age
- 62
- Location
- northside brisbane
- Website
- youtu.be
- 07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
I have a vp with a v6 engine and have a strange issue with my temp gauge ..it takes a lot to get it moving off cold and it just gets to over 1/4 before I hear the fans cut in . It has a L3 dash and when I had a cooling fan relay issue and fan didnt start and engine temp went up ….the over temp light and chime came on but the gauge stayed at a little over 1/2 . I have swapped sender units in the manifold and check the power on the sender unit connector when not connected to sender and it went to 10v so voltage reg in cluster is good . Assumed gauge is issue so I replaced it but displays same thing . Where do I go from here ?
