greenfoam
- Jan 13, 2005
- 7,902
- 128
- 0
- Age
- 102
- VP Executive R-spec
It will be behind the fan, and infront of the engine/belt, there is HEAPPS of room there go have a look before you do you best to complicate it
Another way but it would be a tight fit, is remove the air con and stick the turbo near the firewall on the passenger side and run the crossover pipe just above the gearbox bell housing behind the engine, not sure if that will fit really but it might
P.S Here's some pictures of a crazy under engine, through the manifold kinda setup
Also this link is from FIT's website and is the famous turbo wagon, this is the kind of pipes you should aim for, but in a more budget way (and try make it possible to change spark plugs)
http://www.v6supercharged.com.au/pics/cars_035.jpg
