Vp wiper motor keeps snapping off bracket??
Wagon_Wheel
Drop A Patch....
Mt Martha, Vic
Hey guys. Had my wiper motor snap itself off the bracket not long, so I replaced it last week with one I got from the wreckers. I got the whole motor and bracket and everything and swapped it over. Drove it last night in the rain and it snapped again. The wipers did chatter a bit but didn't think anything of it.
Has anyone had this before?
Anyone know how I can fix this issue?
Geoff
vsl67
VS l67 statesman
I had this happen in my VP it was caused by the mounting bolts working their way loose so check if your bolts are stripped or try loctiting them in
greenfoam
102
VP Executive R-spec
I've had the alloy arms snap off my old VN, but not the bracket. Apparently the VS one can be used and is better?
Brad S15
45
VK Calais EFi 6
Just replaced the wiper motor and linkages in my VP after the linkages jammed and the motor kept turning and instead shattered the cast wiper motor gearbox housing. Grabbed a whole assembly from a VS commo at the wreckers, turns out the plug connecting the motor to the car's loom is different (its still 5 wires but its in a different plastic connector) so I just made up 5 little jumper cables and crimped them to the correct wires and then plugged them into the old connector from the VP which matched the connector on my VP's firewall
