vp wiring diagram
Matt_vp
Donating Member
41
Gladstone Qld
vy lumina v6 A4
does anyone have a wiring diagram for a vp 92 model that they can email me or post on here
regards matt
markovr
62
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
Which part of the wiring did you want?
Matt_vp
Donating Member
41
Gladstone Qld
vy lumina v6 A4
im have a problem where the car will just shut off and when i try to start it the check engine light doesn't come on, but if i arc the 12 volt pin on the dionostic link with the one that goes to the fuel pump a few times with the ignition turned to on the check engine light will come on and the car will start. so i need the a digram with the check engine light, the fuel pump and the computer i guess.
markovr
62
northside brisbane
youtu.be
Heres the ecu diagram that takes in that part
The check engine light is fed a negative by the ecu to it to make it light in the cluster.
Matt_vp
Donating Member
41
Gladstone Qld
vy lumina v6 A4
Thanks for that mate but can i trouble you to post the other half aswell.
markovr
62
northside brisbane
youtu.be
Ive added the whole page to my previous post...you will have to join the 3 pages together.
Matt_vp
Donating Member
41
Gladstone Qld
vy lumina v6 A4
thanks hopefully i can work this problem out now.
Where do you get those wiring diagrams from?
Thanks Matt
m62vpute
Country Vic
VP MANUAL S/C 3.8 UTE
sorry to dig up a old thread but did you happen to work out what was wrong as i have exactlly the same problem with my vp at the moment
m62vpute
Country Vic
or anybody else that is good with electrics have any idea on what could be wrong??
m62vpute
Country Vic
took it to a auto elec today and when i went to pick it up he said he could not find the fault
anybody got any ideas at all i have replaced the computer and memcal tried removing the efi relay to let it reset its self and still end up with the same result
many thanks in advance
