stato79
This is my Stato ive had for 13-14 and have buit up from standard, 200,000ks with nearly $50,000 spent on it. I might sell it for the right $ maybe
304 stroked to 360 (Pro stroke kit)
Scat Steel crank
Scat rods
ACL Larry Perkins race series flat top pistons and bearings
Fully ported and worked VN heads, stainless steel manley race valves, double valve springs
Felpro race series head gaskets
Yella Terra plantnium series roller rockers
C.O.M.E Racing high rise half cut tunnel ram manifold
C.O.M.E Racing cam (big cam unsure of lift n duration)
C.O.M.E Racing memcal
Twin four barrel down draught 1000cfm Edelbrock throttle bodies (barry grant linkage kit)
High flow stroker injectors
Race balancer
Twin Edelbrock air cleaners with K&N elements
Bosch 044 high flow pump
Coil over suspension, adjustable height, dampner, caster and camber front and rear
Clutch industries brass button race clutch
Manual 5 speed (T5 with the bearings done)
VT SS Lsd differential
Monza Rally one piece race seats and harness's (autotechnia)
Monza Rally sports steering wheel (autotechnia)
Custom carpet with Statesman embossed
22inch wheels
Aluminium radiator with twin thermo fans
Monster tacho and shift light
Pacemaker competition extractors with 3inch mandrel bent exhaust
Wilwood 2 piece rotors 383mm diametre and 6 spot calipers
GM chrome low vacuum brake booster
Wilwood tandem high volume master cylinder
VL manual steering rack
Resprayed alpine white
VX bodykit with rear bar modified to suit statesman
Gilmer belt drive kit
Panasonic head deck with 2x500w Kenwood 6x9s, 4x280w Clarion 6inch, Sony explode 15inch sub and 800w competition amp
Tinted windows
Personalised plates
Dyno papers with a video of it pushing out over 300+hp and 530ft/lb at rear wheels with a faulty Haltech at 5000rpm
Scat Steel crank
Scat rods
Race balancer
22inch wheels
Tinted windows
Personalised plates
