oldens
- Jul 27, 2012
- 4
- 0
- 0
- Location
- nsw
- vq statesman / vc wagon
hi all, i have this unknown quantity vq thats been giving us a few headaches, its not standard not sure whats been done to it exactly, i got it because of these issues i have had it 12 months, i took it to a workshop as it wouldnt run properly and this is what was done to make it go not too bad, (it does crack) it has big injectors, the guys said they have not seen before a fuel pump that pumps as much fuel as the one it has the base timing had to be set at 17 degrees! The pressure pumps have been removed all it has is this big high pressure internal fuel pump going through the fuel damper and into the rails! it runs well and on the open road it gets great fuel economy but on full kick from stationary even though the lines are bigger she keeps suckin em dry! My question is can i bypass the fuel damper as well? its meant to be there if there is a low pressure internal fuel pump and high pressure external pump to stop pulsating between the 2 pumps but as i said all it has is a big high pressure internal pump so i was thinking maybe the damper is restricting the flow which is what the pressure pumps at the rails were doing to start with. PS it was at a proper workshop with all the gear when it went not at a backyarders cheers
