vr 5.0 starts then stalls
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Haydz, Mar 21, 2009.
  1. Haydz
    Haydz Fasten your seatbelts
    Liverpool.Sydney,NSW
    VS UTE LS1 T56
    hey guys. been having a problem with my vr
    it wont start. it cranks for ages but wont start.
    but if i remove the lead between the coil and the distributor it will start run for about 30 secs or so. then die.
    what should i be looking for?
    i know its either a fuel or ignition issue. just not quite sure how to check and what to check.
  2. pedrotski
    pedrotski Big Stato!!
    Mandurah
    95 & 96 VS 5L Statos
    clean the terminals on the ignition modual located avobe the air box. see if that helps.
  3. Vt-Brrrlina
    Vt-Brrrlina vp bt1 gts replica
    Perth, Western Aust
    vp bt1 5.0ltr full GTS kit
    could be ya coil on the way out - they get hell munted in there usual location
  4. VrWagz1
    VrWagz1 The Wagon on Wheels..
    wollongong
    VE SSV MY09 Auto Wagon
    Haydz, i dont quiet get what you saud there. If you disonnect the lead between the coil and distributor how does the car work at all, it would have zero spark.
  5. Haydz
    VS UTE LS1 T56
    sorry guys.
    i mean if i disconnect then re connect the lead between the coil and distributor. it will start again.
    but only for 30 seconds or so. then it will stall no matter what. even if i try holding the revs up.
  6. Haydz
    VS UTE LS1 T56
    dont worry guys. must have been some water stuck where it shouldnt have been.
    as i pulled out the compressor and gave all the electricals a good blowing. and know she works.
    no worries. thanks though guys.
