VR 5.0L starting issues
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Vegas304, Jun 30, 2014.
  1. Vegas304
    Vegas304 New Member
    Rockingham
    VR Calais 5.0L
    Hey Guys
    I need some help
    about 3 months ago my car died with no notice, since then i have replaced all leads, spark plugs, coil, dizzy (thinking it was the hall effect), ignition module. My spark comes and goes. I have done TDC after replacing dizzy.
    All grounds are fine as well.
    Im stuck so any advise would be great, Thanks in advance.
  2. Deuce
    Deuce Super Stock
    '94 VR SS V8
    So it starts but soon dies?
    or cranks but does not start?
    or will not crank at all?
  3. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    On top of Deuce's questions, have you set the static timing after replacing the distributor? Needs to be set to 10 degrees BTDC in diagnostic mode (DLC terminals five and six bridged - paper clip or equivalent is fine).
    Do you have a fully charged battery?
  4. jgtoranalc
    jgtoranalc Member
    Adelaide, SA
    Holden Statesman VR HSV 5L, Holden Torana LC
    Have you checked for any Error Codes?
    If you find any error codes, another thing that causes the car to stall is the Air Intake Temperature Sensor (Located on RHS of Intake Manifold, Halfway down, In between the injectors). Now this will popup a code. When it happens, the engine is at normal operating temperature, then shuts down. (So when engine is cold, it won't shut the engine down)
  5. Vegas304
    Vegas304 New Member
    Rockingham
    VR Calais 5.0L
    It Cranks But doesnt start. the car is on charge so not the battery.
    Not sure about the static timing :)
    Checked the error codes came up with 12 System pass. I had to replace the Temp sensor awhile ago as I thought that was giving me the troubles.
  6. BlackVXGTS
    Melbourne, SE
    What do you mean by this? Sounds like you may not have set the static timing correctly.
  7. BottleFedVS
    BottleFedVS Member
    Around WA
    VS Calais 5.0L & 80 Series Landcruiser
    A few years ago i had an issue like this.
    It turned out to be the anti-theft in the BCM had failed and did not throw a code.
    I changed out the BCM eventually (car was off the road for 2-3 months, no idea about forums then just manuals) and the car threw a code 46 i think.
    Hall effect trigger was not working.
    but as the anti theft had buggered up it would crank but not start.
    A lot of people suggested at the time, it was the ignition interface module. however mine turned out to be the hall effect trigger in the dizzy itself.
    If you are going to try to swap bcm's, remember to use the key head associated with the bcm you are using, as this will be a different code.
    also checking the timing was set correctly can only help as everyone makes mistakes once in a while,
    especially like me when I'm tired.
    I hope this helps as I know how frustrating it can truly be!
  8. speed__demond
    speed__demond slammed and cammed
    vic
    vs statesman 5L
    this is really interesting.... ive had key problems for a while.. half the time I turn it and it does nothing, keep trying and it starts fine..
    all of a sudden now it will crank I have fuel spark ect. but no fire..
    could the imtermittent key problem be signs of bcm failiure coming up?.. ive tried my spare key and no difference.
  9. VS 5.0
    The key problem could be related to the silver ring around the ignition that the key contacts.
    I had to have mine replaced years ago due to intermittent starting issues.
  10. speed__demond
    vic
    vs statesman 5L
    yeah.. ill try to bend them out and see what happens.. im just wondering if the bcm or key barrel is bad somewhere could the car crank but not fire
  11. speed__demond
    vic
    vs statesman 5L
    okay no codes... it sounds like its not even trying to fire. its got spark, injector pulse, fuel pressure, tried replacing all relays and ignition module. got me stumped.
  12. BottleFedVS
    BottleFedVS Member
    Around WA
    If you can try swapping out the bcm's and see how you go.
    to buy them new they are not cheap so if you can try a friends that was the same level as yours or pick up a second hander (and key fob),
    that may help eliminate it.
    Like i said before I had the same issue and it would not throw a code until the bcm was replaced.
    Good luck.
  13. speed__demond
    vic
    vs statesman 5L
    if I leave key on ignition it skips bcm doesn't it
  14. speed__demond
    vic
    vs statesman 5L
    my mate (mechanic) tested the fuel press by pulling the line off the rail and see if it pisses out... im not convinced so im changing the whole fuelrail/pressure reg with my spare.
    my thoughts are a buggered pressure reg wouldent have enough pressure to squirt the injectors properly, or it could be leaking up the vac hose and flooding the engine... either way ill illuminate that this morning before I tow the car
  15. speed__demond
    vic
    vs statesman 5L
    so its not the reg... everythings there it just wont go, doesn't even sound like it wants too..
  16. AA6
    AA6 Member
    perth
    Vs v6 ute S2
    Hey man
    If you have spark, fuel, air etc, it might be that the starter mototr isnt turning the motor quick enough to fire.
    Happened to me before on my falcon, changed starter motor and it started.
  17. speed__demond
    vic
    vs statesman 5L
    yea that's just the cool part. 80% of my parts are less than a couple months old. my starter included
    im leaning on the halleffect. its supposed to tell the computer when to do thinks in order. so im thinking if that's playing up now then it aint firing the spark/injectors at the right time
  18. BottleFedVS
    BottleFedVS Member
    Around WA
    Leaving the key on for x amount of time may not bypass the anti theft circuit if it is faulty in the bcm.
  19. speed__demond
    vic
    vs statesman 5L
    as far as the scan tool says it hasn't activated theft status tho
  20. jgtoranalc
    jgtoranalc Member
    Adelaide, SA
    The engine should still crank even if the Hall Effect Sensor is faulty.
