304 VR 5L mods.
brad304
Frankston
VR SS 5spd S2
Gday all I'm new to this forum. I have a VR SS 5spd in which the motor is around 80,000kms old. I have fitted extractors, exhaust, CAI and VT thermos are my current mods. It's currently around 150rwkw and I'm lookin at taking things a step further. I'm not sure what to do but my mechanic recommended larger throttle body and a cam. Not sure if a cam would be worth it unless other mods were done as well? Just want some ideas for a bit more performance at a budget of around 2.5k. Thanks all.
nakaz81
townsville
VK 5L 134 pack
2500? fella, cam and memcal options are the next best thing id say.crow cams have options give them a ring or look the up on the net.if there is a bit of cash left over and you want a bit more torque change diff gears aswell try 3.45 ratio they arnt too bad and give the best of both worlds on the hiway and streetable use.
VrWagz1
The Wagon on Wheels..
wollongong
www.wagzhome.justcommodores.com.au
VE SSV MY09 Auto Wagon
as above. Thats some good things to start with. Cams themselves arnt very dear. Its the tuning and paying for install if you dont do all that yourself. Bigger T/B id say so, dont waste your time.
edit - looking at the date and number of posts, this guy was just a blow-in and abandonned this joint.
xx5047
vrss11
index refference you crank pulley timing mark ,adjust the dizzy to 14-15deg advance at idle for everyday non ethanol 91-96 ron fuel,any more and you need to consider colder plugs and or 96ron minimum fuel
no need to connect the ecu jumper plug either,the whole curve will shift 4-5 degrees.
put some castrol r 5-30 in it while you at it too.
flanker
vn ss hdt aero
Thats fine as it helps others like moi :)
ari666
250,000 hits
i hope you have the dyno sheet to back up your claim. otherwise i have wasted a lot of money with my build and still 3kws behind you with a stock motor...
edit* oh, old thread? soz
Grange 185
vr caprice
3.7 diff gears man all the way it will wake it up or 3.45's ausome mod just done it my self!
greenfoam
VP Executive R-spec
And another old post, I'd back my VP to run VERY near if not over 160 rwkw on a dyno and it's got basically nothing done to it!:)
Cobez
LS-EXUAL
2004 S2 VY SS Ute
As i finally learnt, my Senator, just on 140rwkw on a Dyno Dynamics dyno, but have whooped other 5 litres due to having a fair whack more torque!
I used to think power figures meant all, but torque wins the race!
