VR 5lt engine light problem
brianl622
VS executive
I have just replaced the inlet manifold gaskets in my 5lt and since then everytime i start the car it will run for a couple minutes then the engine light will come on.
I checked for error codes and it is telling me error code 15, I replaced the coolant sensor and it hasn't fixed the problem.
Any comments will be a great help thanks.
VrWagz1
The Wagon on Wheels..
wollongong
www.wagzhome.justcommodores.com.au
VE SSV MY09 Auto Wagon
brianl622
VS executive
Thanks mate
I will have a good look at the wiring
brianl622
VS executive
Still can't find the problem.
Would it be better to pull the inlet manifold off again?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
which sensor did you replace the 1 wire one or the 2 wire one for the ecu
brianl622
VS executive
Found the problem :)
It was a broken wire in the conection
VrWagz1
wollongong
told you it would be somthin simple ;)
