VR Acclaim abs fuse
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by graham7773, Jan 9, 2013.
  1. graham7773
    graham7773 Active Member
    VT Acclaim Wagon
    My grandsons VR Acclaim is blowing ABS fuses. First what size fuse should be in there. 2nd what causes/solutions has any member found for this problem. Please don't suggest leaving the fuse out...I am hoping for an early reply to this as his car is off the road as of yesterday.
  2. K-BAGZ
    K-BAGZ De Plane! De Plane!
    Far North QLD
    VR II S-pac V6 Ute / VZ SV6 Sedan / VZ R8
    The ABS fuse is a 5A by memory. Does the fuse blow when the brake pedal is applied? Or just sitting idling?
  3. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    Never rely on memory - 10 amp fuse.
  4. BottleFedVS
    BottleFedVS Member
    Around WA
    VS Calais 5.0L & 80 Series Landcruiser
