VR Acclaim ABS OFF Warning Light
pjwilki
VR Acclaim
I have just had front wheel bearings replaced and since then ABS Off warning light comes on after 3-4km of travel. Light acts normally when ignition turned on and engine starts (ie off) but comes on at the 3-4 km point. Does anyone have any experience with this problem?
nemesis_adrasteia
better to reign in hell
longford, victoria
VR commodore HSV(without all the gay ****)
hey i dont know if its at all relelvant but mine kept coming on when alterator was playing up
Jecs
PAVTEK Race Engines
Staff member
33
'97 Caprice 355ci & VZ SS Ute
my ABS light is constantly on. then again my whole dash is like a christmas tree with warning lights. gotta love a 99.9 fuel avg.
Calaber
Nil Bastardo Carborundum
Lower Hunter Region NSW
CG Captiva 5 Series 2
When the bearing was replaced, the whole hub would have been replaced. ABS hubs are different to non ABS ones - any chance a non-ABS hub was fitted?
If the hub's OK, check the sensor wiring connection and wiring to ensure it isn't damaged and shorting out on the chassis somewhere.
If that doesn't work, you will probably need a Tech 2 to clear the fault.
