Dunlop
- Apr 13, 2019
- 139
- 26
- 28
- Age
- 68
- Location
- Beechworth
- 1993 VR Commodore Acclaim
I'd noticed over the past few days that the top hose of my '93 VR Acclaim 6 seemed rather hot even though the temp gauge indicated the usual quarter reading and the car hadn't been driven far. Yesterday I decided to check again - the temp gauge read just over a quarter, I know the thermostat's working, and much of coolant has been replaced due to a slow leak. Thought I'd check the temp of the bottom radiator hose and was surprised to find it felt nearly as hot as the top hose! I'd fixed the hvac leak by using a bottle of Rislone stop leak https://rislone.com/au/product/liquid-aluminum-stop-leak/ and it fixed the leak within about ten minutes, saving me just under $800 in replacing the heater core. This additive has a chemical in it that is designed to reduce the surface tension of the coolant to transfer heat more effectively to the radiator and I'm wondering if this might be the reason the hoses seem hotter? The external air temp was around 32C.
