VR Acclaim wont start
stockyvrcalais
VZ SSZ UTE
Hi guys, i'll make it short n sweet, brought a VR Acclaim to strip, has a V6 with 184k on clock, had a busted ignition so i removed rear plug from it and have been trying to start it with a screwdriver, engine turns over but wont start, hasnt ran for about a year, it turns over also by bridging the starter, could it be the immobiliser is on? Im new to this sort of stuff so any help greatly appreciated.
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
You won't be able to start it without the key because the immobiliser will stay on. If you don't use the key, the keyreader around the ignition can't read the key and won't disable the immobiliser.
stockyvrcalais
VZ SSZ UTE
Hi accentstencil, i actually do have the key and i believe the immobiliser is disabled, i was able to press the button on the key head and unlock the doors, however, i cant start it with the key because the end of the barrel is broken. The key reader is there but the part that connects the barrel to the plug is broken. Thanks for your advice.
pjdm1980
Shut up Jr I'm thinkin!
Geelong, Victoria
E1 GTS BUILD NO# 007, GQ Patrol.
Just get another ignition and plug it in to your loom to test it out!
stockyvrcalais
VZ SSZ UTE
today i changed ignition barrel hooked it all up all seems to be working fine, i have spark at the leads, and fuel is being delivered but it still wont start, this ones got me stumped.
accentstencil
71
Is the security light off or flashing when you are trying to start it?
pjdm1980
Geelong, Victoria
Maybe try a fault check.
stockyvrcalais
VZ SSZ UTE
Thanks for the help guys, but i have given up on this one, such a shame a low 184 k engine, but in all honesty i think theres internal damage judging by the noises it was making while cranking over.
