markovr
- Nov 23, 2003
- 3,072
- 252
- 83
- Age
- 62
- Location
- northside brisbane
- Website
- youtu.be
- 07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
Yep that gets the brain cells ticking over...took out the white and white blue wires out of the plug feeding the bcm YB 139 which are the earths for drivers and other doors and disconnected the instrument connectors feeding the light switch and the white/green out of YB139 that is the dome light drive...still no flash on lock so I can rule those inputs out .jc58nc said:One other point I just picked up on while reading about BCMs and key readers is if any of your doors aren't shut properly (earth signal from a door switch) the indicators will not flash to alarm the driver that the car doors are not secure. Could be an earth fault?
My alarm trigger wire that was connected to the light blue l/h indicators feed from the bcm is disconnected atm and when it was connected it had a diode in it anyway.
What I did try is while inside the car I pressed the lock function with the keyhead and the locks went down and the theft deterent led flashed on the console and as always the indicators didnt flash.
I put the key in the ignition and turned it to start without unlocking it with the keyhead and the theft deterent diode was still flashing .....it started and ran no worries but the diode stopped flashing....does this mean that the theft deterent part of the ECU isnt working and that is why I have no flash on arming to alarm me that something is wrong?
Maybe someone with a vr could try this on their car for me to see if this is normal.
Gee this is a saga but I am goin to beat this! At least I am learning something.
