Azwellaz
Kickin' it ole skool
- Apr 26, 2011
- 50
- 1
- 6
- Location
- Mulgrave, Melbourne
- 1998 VT SS 5.0
Hi guys, i have just purchased a a daily which is a 1993 VR Acclaim with the Buick V6, not long after i got it the motor started making a rattling noise, i assumed from previous experience ( Never assume! ) that it was just exhaust heatshield rattle, pulled them off and the noise is still there, after much research and a couple mechanics opinions its been narrowed down to the timing set/chain or the balance shaft bearing, i have yet to pull this apart for a look but i have already decided i am going to ditch the balance shaft and just change the timing set regardless while im there ( Yes chain tensioner, water pump, balancer etc too will be replaced )
Now after many google searches and forum reading i still have a couple of questions that i need straight answers to before i have the confidence to tackle this small nightmare
I do not wish to just replace the timing set with a stock one so straight away i thought of the good ole Rollmaster double row timing set from my V8 days
Problem with this apparently is to make it fit wether you like it or not the balance shaft needs to come out as it fouls the double row timing set, there is also the possibility apparently that the double row set can also foul the oil pump cover in which case you can purchase a new thinner cover from places like MACE or add extra timing cover gaskets to gain that bit of extra clearance, now cars have the most amount of frigging about at the best of times so i don't like this idea even tho i would like the extra strength of a double row timing set
So it looks like i will be going with the Crow CS6VP single row timing set which i guess would be stronger than stock and not have the extra fuss of fitting the double row Rollmaster set
Crow CS6VP link here
CS6VP Crow Cams Timing KIT SET FOR Holden V6 3 8L Commodore VN S 2 VP VR S 1 | eBay
NOW my questions are
Do all Buicks from VN Series-2 to VR Series-1 have this 2 spline oil pump mentioned in the CS6VP link?
And this question is a 2 parter, does the oil gallery holes need to be blocked on the Buick V6's once the balance shaft is removed or does that only apply to Ecotec's?
If the galleries need to be blocked on the Buicks also i have seen that you can just remove the gear from the balance shaft to make it inoperable but then what holds the remainder of the shaft in? Can it slide foward and hit the bigger timing gear causing damage?
Any info would be greatly appreciated, if you have read this far you are a champion!
