The hall effect sensor is a magnetic switch, shouldn't matter which way round it is, check operation with a multimeter set on ohms or continuity to check, should be infinite resistance when open, measurable or zero resistance when closed, (depending on the range the meter is set to) set it to 20k or so and look for close to zero. PM me if you want and we'll get you sorted out, may get you to send some photos.
