vr84
** NOTE TO FUTURE READERS ***
Problem has been resolved, it was the ignition module, can read below the problems that occurred in the lead up to this.
** Original Thread Below **
Hi everyone, wondering if anyone can help me out on this problem.
My RPM tacho had always worked fine until a recent spark plug change and starter motor swap. Since then the gauge is bouncing around however the engine is running 100% normal on petrol.
The gauge will bounce from the actual RPM to about 1000 - 2000rpm above that, then quickly drop back down. This is a new problem that never occurred in the past.
I also have dual fuel, and since this occurred the LPG system is totally out of whack, it can't properly detect the RPM and is cutting out constantly assuming the engine is either turned off or it can't detect the RPM to switch from Petrol to LPG. As such I have been running entirely on petrol recently.
Runs fine on petrol, engine is perfect with no misfires too, just the tacho going crazy.
I'm hoping to find a lead to the tacho problem and try to sort this and see if the LPG then comes back to normal too. Previously the car was running perfect on both fuels and RPM tacho was 100% accurate.
Any help is much appreciated
