VR Commodore 93 turning off while driving.
adamrose
hoppers crossing
VR Commodore
Hi People, As above I am having a problem with my VR while driving,The motor just shuts off and I have been reading a few threads and I see that it could be a few things and if I went by these threads I would be spending way above my budget.
Story and Symptoms ~ My Beast has been running a little rough of late and was going around a roundabout the other day and I lost a bolt on the Rod&Swaybar and it popped and I did not even realise but after a few days I have started having engine problems "shutting off while driving" again because a year or 2 ago I changed the coil plate for a similar problem, and it was fine since.
If I sat here trying to work it out I would get nothing done so yer just wondering how much it would cost to get somebody to come out and determine the problem normally! I can change the sway bar and that but troubleshooting car problems it not my thing :(
rambunctious
Alexandra Headland Qld
VZ Executive Wagon and VZ Ute
I had a VP which used to shut down sometimes.
Changed the CAS for a second hand one from the wreckers and never had the problem again.
Or maybe the old problem you had has started again.
adamrose
hoppers crossing
VR Commodore
I replaced my spark plugs and leads not long ago and was just thinking could a bad spark plug shut the engine down while driving or cause a bad reading.
losh1971
North Tas
VE Series I SS Ute
I had shot plugs and it still run ok. My guess is fuel pump, CAS or DFI.
adamrose
hoppers crossing
VR Commodore
A friend said to me awhile ago that my coils could probably do with a change so yer I might start there since I have already done the plate.
See how it goes and if I pump the pedal while trying to start it it will eventually start but sound and run like absolute ****.
Thanks for your help dudes I really appreciate it.
losh1971
North Tas
VE Series I SS Ute
It will miss like a bastard under load but probably not die, even if a coil was completely shot. Given this new info it probably has to do with some sort of sensor on the TB, a broken vac line or maybe a pump, filter or reg issue. Start by looking at broken vac lines as that sounds the most likely culprit, right now.
adamrose
hoppers crossing
VR Commodore
hey me again quick update, I got a friend over and we took the plugs out and leads out and cleaned them up with a wire brush and WD40 and put them back in 1 lead was stuck and broke when getting off so I had a spare put it all back on and bam the car was running like butter again :) gave it a bit of a rev to clean it up a bit and it seems great thanks for help close thread. The simple things are sometimes the answer.
