VR Commodore fault code
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Chris .p, May 4, 2011.
  1. Chris .p
    Chris .p New Member
    Toogoom
    Vr Station wagon x police
    yesterday the old girl decided to throw a tps fault code ( code 22 ).replaced the sensor, to no avail. tract the wiring back to computer no issues, and this fault wont leave me alone by the way all voltages are perfect at the TPS ???????????? im getting greyer by the hour.
    if anyone can give help on this it would be much appreciated.
    Chris
  2. db_notso
    db_notso diagnostic technician...
    sunshine coast, qld
    vt v6, mods(susp brakesetc...)
    Code 22 - Throttle Position Sensor (TPS) low voltage
    cleared the code after replacing tps? (have to ask)
    if there is any movement available when screws are loose on the tps try setting it both ways as far as possible and retrying
    check the new one is the same as the old one, e.g. cap under tps where it fits on etc.
  3. Chris .p
    Chris .p New Member
    Toogoom
    Ive tried all of that im thinking map sensor or ecu, what do you think.
    cheers
    Chris
  4. Chris .p
    Chris .p New Member
    Toogoom
    thanks for your help, it turned out to be the little plastic grommet that goes on the end of the shaft it was sitting on driveway.
    don't i feel like a moron.
    Cheers chris
  5. VR_Acclaim
    VR_Acclaim Banned
    Vr acclaim
    no i done the same thing when i done mine lol
  6. db_notso
    sunshine coast, qld
    seen four or five times too :)
