VR commodore idle problem.
bigjase73
50
wynn vale
vr commodore
hi all. my vr has started to idle rough intermittently. it does this when I go thru the gears(auto) and have noticed the tacho drops to nothing,even when engine is running then comes alive after a short splutter could this be the TPS??
bigjase73
50
wynn vale
vr commodore
If I remove the TPS sensor will the car still function?
losh1971
North Tas
VE Series I SS Ute
Quite often the TPS will affect gear changes. It can often stop it shifting up when they get real bad. When they first start to go the engine will labour and rev out a lot more when taking off and getting up to speed.
bigjase73
50
wynn vale
vr commodore
thanks mate, are they expensive to fix? or can I just get one and install myself?
losh1971
North Tas
VE Series I SS Ute
35 bucks for a Delphi on eBay. I paid a mech 20 bucks to install mine. Easy enough to do yourself.
bigjase73
50
wynn vale
vr commodore
thanks losh, do u know if that would affect the tacho from working as well, it sort of stops for a bit on idle then stutters then comes back to life again with the engine running??
losh1971
North Tas
VE Series I SS Ute
I doubt it. It never affected my tacho when my TPS died.
bigjase73
50
wynn vale
vr commodore
thanks again mate, the old girl has been so reliable to date( 265000ks ) and don't want to get rid of it just yet, the car I mean,lol, hopefully I can find this issue and resolve it asap
vs-lover
VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
The down side to this is that it can be a myriad of things from an IAC, TPS or even a vacuum leak. I still haven't been able to totally eliminate a similar issue with my wife's VS Acclaim that had the vacuum line from the throttle body to the purge solenoid continually come apart.
At this point it still wants to hunt up and down but no where near as bad as what it did when the vacuum line came apart.
