Vr commodore problem would love some help
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by luv my vr commo, Jan 13, 2011.
  1. luv my vr commo
    luv my vr commo New Member
    perth
    1993 vr commodore
    Hey im new to this and would like some help i have a 1993 vr commodore which has a little problem every time i go around a corner fast or go side ways the car loses all power doesnt turn off just loses power all power returns when i straighten up.
    Any help would be much appreciative
  2. db_notso
    db_notso diagnostic technician...
    sunshine coast, qld
    vt v6, mods(susp brakesetc...)
    does the car have abs?
    does it lose power as in you cant rev engine at all? (accel pedal does nothing?)
    is there an engine light on?
  3. luv my vr commo
    perth
    1993 vr commodore
    no engine light on and yes accel pedel looses all function car doesnt stall and get all power back when i have straightened up ?
  4. NickVR
    NickVR Active Member
    Adelaide, SA
    VR Executive A4 V8
    Usually a fuel pump will cause it to stall when going around corners or a damaged fuel tank. Is it only when it's low on fuel? If it is that would be the problem, a full tank would stop this. Or maybe stop going "sideways" if your not on the track that would be a good fix too.
  5. luv my vr commo
    perth
    1993 vr commodore
    na even when i have a full tank it still cuts out as when i go around a corner fast engine cuts out but doesnt stall and i get all powwer back when i straighten up . i have no clue
  6. db_notso
    sunshine coast, qld
    http://forums.justcommodores.com.au/vr-vs-holden-commodore-1993-1997/72197-dodgy-fuel-pump.html
    the v6 doesnt have abs and im assuming its not an ss...
    so the above link is what youre looking for good luck
    i will say though when you drop tank out replace pump sender its carrage and hoses inside tank
    this is all based upon the dash lights not all losing power when fault occurs if all dash turns off its a power supply problem near the battery check and tighten all you can get too
    terminals engine earths etc
    unless you have BT1 police pack it may have abs
  7. NickVR
    Adelaide, SA
    VR Executive A4 V8
    The V6's do have ABS. Calais was standard and Berlina was optional. Even the acclaim had the ABS option too, may have even been standard but that might be series 2. Also IRS as option and standard on these too. (calais and Acclaim standard, unless wagon and Berlina optional).
    Holden VR Commodore - Wikipedia, the free encyclopedia
  8. db_notso
    sunshine coast, qld
    fair enough
    do they flash the abs light on dash when abs is active? if so good way to tell if hes just having an abs event!~
    but am unsure as to which models and levels had abs on vr
    took me a month to find a vt without abs!~ sounds stupid but to find a good one anyway... was worth it for the odd skids now and then
  9. VZ57SSZ
    VZ57SSZ Member
    Central Coast
    MY16 VF Series II SSV
    my old VR had ABS and an LSD never had any problems when the car kicked out with loosing power in fact once it lost traction it kept on spinning. So doubt it is to do with the abs
    or as said stop sending it sideways I used to only do it on tracks
  10. NickVR
    Adelaide, SA
    VR Executive A4 V8
    They have an ABS off light on the dash but I think that is the only ABS related light on there. I think you could actually turn the ABS off in the VR/VS model (If not just VR) as well.
  11. luv my vr commo
    perth
    1993 vr commodore
    na mine doesnt have abs . just a normal vr only ever happenes when cornering at a decent speed ... everything runs really good when in a straight line and cornering slow but at a decent speed is when the problems start .
    many thanx for all your help
  12. db_notso
    sunshine coast, qld
    yeah id go with the fuel issue listed above
  13. luv my vr commo
    perth
    1993 vr commodore
    cool thankyou for your help
