vr commodre tps are they screwed in or alan keys
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by auz_tas12, Dec 14, 2011.
  1. auz_tas12
    auz_tas12 New Member
    brisbane
    vr 5 speed wagon
    ok i tried put a screw bit on the sensore but no go or flathead what typed of screw are they cheers?or are the screws a special bit to unscrew the sensor
  2. James39
    James39 Gave up on VL's
    Newcastle NSW
    1995 VS Acclaim & 1992 Holden Barina
    I assume the VS would be the same.. I removed mine with a phillips screwdriver...
  3. auz_tas12
    brisbane
    vr 5 speed wagon
    hmm mines underneath are the vs the same tried screw driver no go
  4. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Use a small mirror and a torch to have a look.
  5. Wombles
    Wombles Cars cost too much.
    Might need to crack the seal the thread has.
  6. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    Some VR TPS screws are size 20 (T20) torx type screws, You will need a size 20 (T20) torx driver to undo them..
  7. Scrubmonk
    Scrubmonk Member
    Mildura, Vic
    VS Executive S2 V8
    Agree, they are torx screws. Be careful, the screws have a habit of oxidising to the alloy throttle body and snapping off when trying to undo them. Give them a soak with something first to free them up. It only takes 10mins to whip the throttle body off, and it would make the whole job easier plus you can give it all a good clean up IMO.
  8. auz_tas12
    brisbane
    vr 5 speed wagon
    yer torx key took throotle body of gave it a clean then put tps sensor on now its idle good not running lumpy or stalling or evan fumy so far so good but engine light is stayin on now lol
  9. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    You need to disconnect the battery for 30 secs or so, or alternatively take out the engine fuse (located in the fuse/relay panel under the bonnet) for a similar amount of time. That will reset any logged trouble codes in the ECU. If you have any more trouble codes logged after that you need to address them. Did you remember to make sure the drive adapter (small white plastic item) was replaced in the correct position?
  10. auz_tas12
    brisbane
    vr 5 speed wagon
    yer mate the little plastic thing on tps is on and i rested the ecu but engine light is stayin on wtf lol?
  11. Scrubmonk
    Scrubmonk Member
    Mildura, Vic
    VS Executive S2 V8
    Have you tried resetting the TPS? After disconnecting the battery for at least 10secs to reset the PCM (ECU), you need to reset the TPS by starting the car, reving to 2000RPM for at least 10secs, then turn off the car.
    Not sure if it will fix your problem, but worth a try.
    Did you just take your TPS off and clean things up, or did you replace it with a new or secondhand item?
    Are getting any error codes?
  12. James39
    Newcastle NSW
    And since that, what error codes are still showing up?
    At any rate leave the battery disconected overnight then see what happens............
  13. SWE11L
    SWE11L New Member
    VS Berlina/ KJ Verada/ 88 Trans Am
    I replaced my tps with one from the wreckers recently ( I pocketed a second just incase the first was a dud, I don't condone theft! ) and it ran at slightly higher revs and the engine light stayed on, I replaced it with the second one I got and it was fine. Maybe your replacement is a dud.
    How important is this revving to 2000 or 3000 rpm's? I've heard of this a few times now...
