vr dead lock stuck
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jaygen3, Mar 11, 2007.
  1. jaygen3
    jaygen3 New Member
    vx v8
    hi guys and girls last night i dead locked my old mans vr and it got stuck and will not unlock i was lucky that the back door does not lock and i could get in.just asking if this has happend to one of yous because i need help my olds is gunna kill me.Dead. :rip:
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    I've seen mention of this before and thought I'd check mine.....mine virtually froze solid after I turned the key anti-clockwise to lock it - spent a few minutes panicing but with gentle coaxing it unlocked - remember to turn it clockwise to UNLOCK. Good Luck.
  3. AttaBoy
    AttaBoy WTF?!?!
    VS Acclaim V6
    mmmmmm...... I better stop deadlocking mine from now on just in case it happens. (been deadlocking my car ever since I got it lol...)
  4. Jon Z
    Jon Z New Member
    QLD
    97 VS Series 2
    one question? why did you bother dead locking the car if the back door doesn't lock?
  5. AttaBoy
    AttaBoy WTF?!?!
    VS Acclaim V6
    mmmm... good question!!!
  6. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    I think its OK if you use the deadlock all the time or at least fairly often. Most deadlocks have never been used which means the actual switch etc is dirty and dusty and probably a bit corroded as well. If you don't use it you will lose it.
  7. ephect
    ephect Donating Member
    VS Acclaim V6
    i think ur main problem would be your key is a lil too warn. My deadlock does this most of the time now, now my boot is starting to do the same, a lil bit of jiggling works but u've gotta find its sweet spot. Maybe try getting a new keyblade and see how it goes, thats next on the cards for me
  8. jayderichards
    jayderichards Member
    Adelaide, Australia
    2000 VS SIII Ute
    mine used to lock and unlock for a while, but when l stopped using it as much it refused to work. I got some WD40 and gave it a tiny little squirt through the key-hole... waited 24 hours and it worked. I've been using it everyday and haven't had the slightest trouble
