VR door lock wiring
stew58
62
hi guys, replacing door on me VR sedan, just having prob with lock wiring,
iv got the main cable pluged in at the bottom of the lock,
but there is this smaler cable ( 3 wires in it black, brown, red\yellow)
that has a microswitch on the end of it,
where on the lock does this go?
evil_monkey
Australia
Holden
that wire/switch goes on the door handle itself closest to the key hole theres two metal lugs that it sits in and then a metal clip holds it in place and theres like a bend in another metal clip that if you turn the lock with the key it lines up with to push the button what it does is operate the deadlock mechanism but its not cruciale to be installed i actually had problems with myne when i mounted it so i just left it and made sure it didnt make contact
stew58
62
thanks for speedy reply evil_monkey :)
