VR drivers door lock "bouncing"
Pusser
VR 5L sedan
Morning All
When I lock my VR's doors with the button on the key all the locks go down and then cycle immediately up again. If I manually push the drivers door button down all doors lock and then unlock fine with the button. I thought at first the orange locking piece on the drivers door lock was stopping it going down or that the button was out of alignment but it does it even with the button off. Any ideas anyone?
losh1971
North Tas
VE Series I SS Ute
Sounds like an actuator is on its way out, likely the drivers side.
markovr
62
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
Morning All
Called machinegunning and can be just adjustment but probably the lock motors switch making **** contact.
Pusser
VR 5L sedan
Thanks Mate, I'll try adjusting before I swap it out.
losh1971
North Tas
VE Series I SS Ute
I don't recall VRs having any adjustment......?
Drawnnite
Obviously Unsensible
2000 Vs Ute
Had a similar thing with the vs.
Cleaned the plug with contact cleaner (cant remember if i could open it and cleaned that too, its been probably 8 years) and manually cycled it through a few times.
Eventually came good again.
Pusser
VR 5L sedan
Thanks mate, I'll give that a try. I'll admit I couldn't find an adjustment, but I may not be looking in the right place.
