VR engine into VS
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by vsowner94, Feb 7, 2011.
  1. vsowner94
    vsowner94 New Member
    Albury
    VS Executive s2
    hi everyone, just wondering if a VR engine would fit into a VS and if its just a drop in and go method or if there is alot of work involved
  2. cander24
    cander24 New Member
    NSW South Coast
    VZ GTO. VS LS1.
    Physically, yes, but the wiring, pcm management and bcm etc. is all different and would also need to be changed. HOWEVER, this would not be legal and pass any inspection etc as you cannot put an older commodore motor in a newer body. It must be replaced with an engine option that was available in the vs body or alternatively a newer motor with engineering etc. Basically you're best off to replace it with another ecotec V6
  3. pjdm1980
    pjdm1980 Shut up Jr I'm thinkin!
    Geelong, Victoria
    E1 GTS BUILD NO# 007, GQ Patrol.
    And exhaust, fuel lines and VS motors cost about the same VR ones so doesn't make financial sense.
  4. justbad4you
    justbad4you IF YOR NOT A HOLDEN
    MELBOURNE S/E BAYSIDE
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    i put a vs eng back into you vs...less hassles and the ecotec is better on fuel than the buick
