Reed93
- Apr 14, 2014
- 12
- 0
- 0
- Age
- 30
- Location
- Reservoir, Victoria.
- VT Calais L67
So i have got a series 1 vn engine, other than the crank being 6 bolt and intake manifold being different is there any other major differences between series 1 and 2 ?
Could i just put a series 2 crank in and intake manifold ?
Anyway ill be doing a rebuild over time and using this thread to upload photos ect for anyone thats interested.
Im not loaded with cash so it wont be done in a couple of weeks or anything as machining costs a bit of coin.
Why rebuild a v6 an not just get a second hand engine ?
Well i like to give my cars a bit and also use it as a burnout car.
Its a Manual VR for those that were wondering, ss kit, full leather seats with calais dash, spooled, pacemakers ect.
Back to the subject the reason why i would like to rebuild one is i know it will be fresh and should last me atleast 2 years until i get off my P's. I have a bad habit of doing bottom ends. Upto 5 now. And changing engines every couple of months gets old real quick.
Anyway this is what im looking at getting. Have i missed anything ? Anything you would change ? It will be a n/a engine with a mace cam so should i up the compression or leave it as is ?
Anyway current list is:
Oil Pump
Main Bearings
Big End Bearings
Cam Bearings
Cam & Chip
Water Pump
Head Bolts
Rocker cover gasket
Thermostat Seal
Block Girdle
Pushrods
Throttle Body
Valve springs
Hydraulic Roller Lifters
Machined oil pump cover
Double row timing chain
Thermostat
Hypatec pistons
Unsure whether i can use stock conrods with the hypatec pistons. Or can someone reccomend any? Keep in mind it will not be a race car engine so i dont think forged would be needed but something that can handle high rpm as i will be taking it to heathcote skidpad every now and then to get it out of my system.
Anyway thanks for reading. Began to strip the engine today. Will finish tomorrow.
Oil Pump
Main Bearings
Big End Bearings
Cam Bearings
Cam & Chip
Water Pump
Head Bolts
Rocker cover gasket
Thermostat Seal
Block Girdle
Pushrods
Throttle Body
Valve springs
Thermostat
Hypatec pistons
![k9ezhw.jpg](http://i58.tinypic.com/k9ezhw.jpg)
![muvcax.jpg](http://i59.tinypic.com/muvcax.jpg)
![2cna2h0.jpg](http://i58.tinypic.com/2cna2h0.jpg)
