just wondering what some of the warning lights mean on the dash and how to connect most of them up. "press remote". and how to connect the chime, temperature and low fuel warning light?
from what i've read, "press remote" is left in from VN-VP clusters, the low fuel warning light is sent from a trip computer OR speed alert, the chime is located only on level 3 clusters (im pretty sure) and the temperature... isn't that standard?
what is press remote used for? is it easy to connect the speed alert and make it work in my VR? well when i turn the key the temperature light doesnt light up for a few seconds so i thought maybe u have to add that as well?
speed alert is a bit of extra wiring read here http://forums.justcommodores.com.au...1997/37373-how-install-speed-alert-vr-vs.html
If you havn't yet got a speed alert module, I would recommend a trip computer with level 3 cluster over that. http://forums.justcommodores.com.au/vr-vs-holden-commodore-1993-1997/994-tripin.html may help
is the level 3 cluster with digital odometer? how do i set the kms to mine when i get one? and is the trip computer bought separately and put where the speed alert normally goes?
Yes its got the digital odometer To set the KM's you need to pay someone to do it (or buy one with similar kms) The trip computer MIGHT come with it... depends where you get it
