VR Faulty Instrument cluster
GSR
I've lost digital read outs for trip computer,litres per 100 ks, odomter etc. Needle gauges work ok. Anyone familiar with this? Do I need a new instrument cluster?
pjdm1980
Shut up Jr I'm thinkin!
Geelong, Victoria
E1 GTS BUILD NO# 007, GQ Patrol.
Have you got a mate that you can borrow one from or maybe try the fuse or a loose connector?
88GreenVN
Next Exit Left
58
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
If the ODO is not showing when the car is off the cluster has lost 12 v power via the orange white wire in the 4th plug.
GSR
The ODO is on when car switched off but only half of numbers showing. It started on the left of the three displays, then the middle one went now I'm slowly losing ODO, kms left display on the right hand side.
JAAV
Broome
VR wagon, 5 ltr ski boat, VS ute, VT calais.
The plastic conector membrane develops hair line cracks same as the analoge dash..
Very fine and low temp soldering iorn and alot of practice..
88GreenVN
Next Exit Left
58
Surprise, Arizona
Most probably 2 things - 1. The LCD's are dead now and will need replacing. 2. the white fascia holding the LCD screens in place has failed releasing the pressure needed for the screens to work - it will need glue and some know how to fix.
GSR
Thanks for your input guys. Much appreciated.
