VR fuel ecomony 5.5 litres per 100k
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by john230873, Jun 11, 2006.
  1. john230873
    john230873 Guest
    Found a new thing last night. Coming back from a long trip notice that my fuel per 100 km was reading 5.5 litres driving at 100kmh, normally this is at 8.5 to 9 litres per 100 km.
    Turn out that each time I turned my high beams lights is when my fuel per 100km went to 5.5 litres.:hit: If any thing the fuel per 100ks should go up.
    Trying to track down what is going on someone has suggested the alternator might not be producing top performance and when I turn my high beams on the fuel pump might not be getting enough power and the fuel pressure is dropped causing the drop in litres per 100ks.
    Has anyone else had this?
  2. Fatboy
    Fatboy New Member
    5.5 L / 100km? That is a figure a little hyundai would be proud of. I think something is wrong there.
    Also if your fuel pump was not giving you enough fuel, I'm sure you would know about it going at 100 kmh. Good luck finding the cause!
  3. Fekason
    Fekason Fekason
    Penrith NSW
    Lcd?
    Could it be that the LCD on the trip computer is on the way out?
    5 is 8 minus two lines on the left.
  4. john230873
    john230873 Guest
    No it not that becuase I turned the high beams off and the computer rose back to 8.9
  5. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    I'm with Fekason and the digits - brilliant off-centre deduction.
  6. Fatboy
    Fatboy New Member
    But the OP is saying the digit 8 is being displayed fine.
  7. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    Does anyone know exactly how the fuel consumption is measured? - is it flow or pressure or what.
  8. john230873
    john230873 Guest
    I did some more testing tonight and found the more load I put on the electronics the more the Lper100km dropped.
  9. Fekason
    Fekason Fekason
    Penrith NSW
    Measurements.
    I believe that the fuel consumption takes readings for distance from a transducer (I think) at the transmission, and fuel flow based on fuel injector pulses registered at the computer.
    Can be calibrated to be very accurate, but is reasonably close "out of the box".
  10. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    Thanks Fekason. Regards
