vr issue starting
yoshi87
south australia
vs commodore
hey guys i have a vr sedan, we r getting spark, petrol is getting thru, we have changed the fuel pump, injectors, and still no start, its not coming up wth any error codes
plz help
K-BAGZ
De Plane! De Plane!
Far North QLD
VR II S-pac V6 Ute / VZ SV6 Sedan / VZ R8
Accelerator pedal flat to floor and crank.
K-BAGZ
De Plane! De Plane!
Far North QLD
Spark plugs ok? Leads ok? Lead orientation correct?
Fuel hoses back on correctly?
yoshi87
south australia
vs commodore
hoses on correctly, gettin lots of spark, car was running fine, then started to play up so my mate changed fuel pump and filter still playes up so we changed injectors, and still no joy
James39
Gave up on VL's
Newcastle NSW
1995 VS Acclaim & 1992 Holden Barina
DFI or Crank angle sensor..
walter
perth
vr statesman 5 litre
Hi just joined today as I am having trouble with my car hoping someone could help? I have a 1994 VR statesman. Was going good had it out and rev counter started to bounce around with out motor revving... got it home and it was sounding a bit off....went out in morning started first pop run for maximum of 5 seconds died and wont start again..I have had a look got no spark..have changed coil...been told to replace ignition module have taken off distributor cap have removed ignition rotor now am stuck as I cant get what is under the rotor off could someone please help as I dont really know what I am doing
James39
Gave up on VL's
Newcastle NSW
But if it was one of them, wouldnt it come up with error codes?
Not always. The CAS on my VS failed but there was no codes...
yoshi87
south australia
vs commodore
hmmm i c, mate is gonna change his cas, and hopefully the dfi, if i have the spare tomoz
