VR lvl 3 cluster screwed!
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by SUSS8, Sep 30, 2011.
  1. SUSS8
    SUSS8 Member
    Western Suburbs, Melb
    '94 Holden Calais VR V8
    My speedo light bulb blew a while ago but the two side ones were working up until recently. They ended up going out too but everytime I smacked the top of the dash they would come back on. The other day I was driving and I started smelling like an electrical burn and noticed the all 3 globes were out any way changed them all today and nothing. Checked all the fuses and contacts everything was good but still no luck.... Wondering if any could shed some light!!!
  2. SUSS8
    SUSS8 Member
    Can anyone help? I wanna see if I can't find the problem before going to an auto elec
  3. HamaTime™
    HamaTime™ VIP Member
    VE SSV G8 & RV6 4Runner
    First things first, do the globes just not work or has the entire cluster died/do any of the gauges/needles work?
    Take your cluster out, and have a detailed look at the Green Plastic Membrane which covers the back of the cluster (and has all the copper lines running from the plugs to the various functions of the cluster...
    Check for any damage of any kind, breaks in the copper tracks etc...
  4. SUSS8
    SUSS8 Member
    Just the globes don't work and I had a look behind the cluster and the membranes seem like they are all making contact and don't see any burns in it either
  5. SWE11L
    SWE11L New Member
    VS Berlina/ KJ Verada/ 88 Trans Am
    can the copper lines be fixed if there are score marks from twisting bulbs in and out?
  6. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    Use a bit of alfoil and fold it over both sides of the PCB - you may need to take it half off to do this. Make sure the globe tags are not too tight or it will just rip it.
    Clean off any green coating if you need to make a contact a little way away from the main contact area where the globe goes in. Super glue alfoil in place once the globe is in. Hint once the globe holder is in place the bulb can be pulled out from the holder without taking it out of the cluster again so can be a perm't fix.
    I have made this repair several times when out and about fixing clusters for people.
  7. 88GreenVN
    Surprise, Arizona
    Are the globes blown - can happen. Swap fuse 1 over with another one see if that helps - I have seen fuses that look OK but still fail.
  8. SUSS8
    SUSS8 Member
    Swapped fuses around and changed new globes
  9. 88GreenVN
    Surprise, Arizona
    Then the cluster is not getting 12v to the globes or the earth is bad. From memory the brown white wire feed power to the globes. See if you have power at C2#4 with the parkers on.
  10. SUSS8
    SUSS8 Member
    Just checked and it's got power by still won't turn on. If the headlights are off and I turn the key to ACC the lights flicker on and off really quick and that's it. Checked the back if the cluster and doesn't seem to be any burns or any bad connections so I'm stumped
  11. SUSS8
    SUSS8 Member
    Still havent figured this out it's really annoying now. Any auto elecs on JC that could suggest anything really need the help!
  12. James39
    James39 Gave up on VL's
    Newcastle NSW
    1995 VS Acclaim & 1992 Holden Barina
    Might need to get another cluster to test things out?
  13. SUSS8
    SUSS8 Member
    Been trying to get a hold of one but got no luck in getting one to borrow.
  14. SUSS8
    SUSS8 Member
    Anyone know a decent auto elec in western suburbs? Still haven't worked it out and it's becoming difficult driving at night !!
  15. markovr
    markovr Well-Known Member
    northside brisbane
    07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
    instrument lights get powered from 2 sources on printed circuitboard so if all the lights are out it probably wouldnt be the tracks on the cluster.....probably 3 other potential sources of this fault.....wiring , headlamp switch or body control module.
    Does the dimmer work for the other lamps in the dash like the console etc other than the cluster?
    Illumination circuitry for the cluster lamps are fed straight 12v+ and the negative path is dimmed through the bcm electronics.
    The dimming circuit uses a grey wire in the return path from the negative of the cluster lamps to the bcm.
    Take out the dash cluster and try temporarily attaching a bit wire on instrument connector 2 terminal 5 (make sure it is on a grey wire) Thats the middle connector that sits in the plastic behind the cluster on the top row of terminals.....5 in from the left as you look at them and pluging the dash back in, turn the lights on and earthing this wire to metal of car...if instrument lights come on the fault will be either bcm or in the return path at least.
