Vr Manual Question
Newcastle
WL Statesman....L67 VS Berlina
Hey guys im just wondering for all you 5 speed owners
when you are in either 1st or 2nd giving it a bit of go say 4k rpm
does the gearstick move about 3 - 4cm to the right?
is this normal engine/gearbox twist?
or you think the gearbox mounts or engine mounts have karked it?
any help would be good thanks
HÝPÕ-5L
33
West Side
profile.myspace.com
Blown V8 94 VR Manual Ute
yer it is normal to move a little i think from the torque of your engine, my worked 5 litre did it and the rubber was brand new, id be in 2nd doing about 3500RPM's and plant it the gear stick would move.............
justbad4you
IF YOR NOT A HOLDEN
MELBOURNE S/E BAYSIDE
97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
should have a little bit of movment>from what your saying yours sounds ok
HSVBOY89
narangba
VS HSV MALOO 5LTR 5SPD
my thoughts
i drive a maloo 5spd 5ltr im running a t5 croww cams mandral bent exaust hurricane extractors chip and a few other minor mods it goes hard, buut.... my gearbox is as tight as a nun.... has like maybe a centermetre if that of movement at full throttel so idk man i would be worried if mine had that much movement as im so used to mine being tight but yeh just my thoughts im no expert :):surprise:
justbad4you
IF YOR NOT A HOLDEN
ok dosnt mean perfect(from what he has stated id say hes is fine) he gearbox rubber may be worn a little
Whales
Newcastle
Vs Series 3 Ute, manual. Hz Pano 5.0L injected
Mine didnt move then my mate borrowed it and now it does the same and moves about 3 cms in 1st and 2nd...and i've noticed that in 1st and 2nd that if I take off my feet off the pedals and try and pull it out of gear it wont slip out but it will in 3rd 4th and 5th :(
WTF is going on...broken mount somewhere???
