vr mounting stereo unit
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by bazza250, May 10, 2008.
  1. bazza250
    bazza250 New Member
    vr acclaim
    Any tips on how to mount a jvc head unit into a VR auto?
    i have removed the old standard eurovox tape/radio! the brackets from that do not line up with the new cd player.
    anyone done this before and can guide me, any help will be greatly appreciated.
    is there a mounting kit perhaps that i can buy?
    i have the wiring sorted using a aeropro adapter into the existing loom.
    i wired it up colour for colour the head unit wires are the same as adaptor wires so i just joined them together. havent tested it yet thou?
  2. r_i_d_a_h
    r_i_d_a_h New Member
    '97 VS Commodore + '98 E36
    had the same problem with a few installs in my time...theres nothing a power drill cant fix.
    either drill new holes in the old eurovox brackets OR carefully drill new holes in the sides of the new head unit.
  3. coasty
    coasty the voices told me to
    kanwal nsw
    vz equipe & vt berlina both v6
    i prefer the drill being used on the brackets. just safer. make sure you measure and mark the holes correctly. its easy. did my daughters cd player amp and sub in 2 hours.
  4. Andrew426
    Andrew426 Active Member
    New Plymouth, New Zealand
    VP calais, VR Berlina, VJ valiant, BG5 legacy
    I taped the old brackets to the side of my new headunit with gaffer tape. Pretty awful, but its never moved on me.
  5. Chirpstr
    Chirpstr A new project attack
    VR Berlina M5, VP M5
    I had that problem with my JVC. I just made up some new brackets but there is a annoying space between each side and top that I should fix some time with thicker metal.
  6. bazza250
    bazza250 New Member
    vr acclaim
    Damn right theres no way im drilling holes into the head unit, thats crazy talk!
    So you dont have to use the cradle that comes with the new cd/player?
  7. Chirpstr
    You may get away with drilling new holes in the cradle yes.
  8. whitevrboi
    whitevrboi Just another white vr.
    VR Executive S2
    i had the same problem, went to bunnings bought some metal stripping and made some brackets to screw onto the cradle, it fits fairly snugly but the ends of the screws rub on the head unit as you pull it out. its not a problem just makes it more secure lol.
  9. bazza250
    bazza250 New Member
    vr acclaim
    you misunderstood my question!
    is it neccessary to use the cradle that comes with the new cd/player?
    or just the old brackets with new holes drilled in them to line up with the new unit?
  10. r_i_d_a_h
    that cradle never came to any use with me, i dont see how it would work with the VN-VP
  11. bazza250
    bazza250 New Member
    vr acclaim
    so just use the eurovox brackets then?
    how do you get it to sit flush with the surrounding facia etc?
  12. Chirpstr
    Yes use the eurovox bracket and drill new holes if possible.
    If it doesn't sit flush then measure the remains and make a bracket to suit.
