vr no power after engine change
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by mark b12, Mar 9, 2018.
  1. mark b12
    mark b12 New Member
    vr comodore
    hi all,i swapped my vr commodore engine and while I was doing it I didn't realise the positive wire to the starter motor was not attached I hooked the battery up and i did not realise the wire was earthing under the car,,i hooked the starter wire up and hooked the battery up and I have no power at all,,no lights indicators ignition etc,,is there a fuse that could have blown ?
  2. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    You can check your 60a main. Failing that try all the fuses under the bonnet.
  3. mark b12
    mark b12 New Member
    vr comodore
    will do thanks losh1971
  4. losh1971
    North Tas
    VR Ute V6
    No worries let us know how you get on.
  5. woteva
    woteva NEED 4 SPEED
    Adelaide S.A.
    Got a multi meter?
    Is the battery OK?
  6. mark b12
    mark b12 New Member
    vr comodore
    hi all,i checked the 60a fuse and it does look kaput,,need to get hold of one from auto shop,,will do this over the weekend nd let you guys know how it goes thanks all
  7. mark b12
    mark b12 New Member
    vr comodore
    hi all again,,checked battery fuses n leads all goo,,do I need to change the bcm,,as I said there is no power at all
  8. losh1971
    North Tas
    VR Ute V6
    Have you checked every fuse, both under the dash and under the bonnet?
  9. mark b12
    mark b12 New Member
    vr comodore
    all fusses are good double checked them all,,,battery fully charged,,i don't understand why I would have no headlights,indicators etc could the vat be the reason ? or bcm ?
  10. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
    VATS and the BCM won't stop power or accessories, they will only stop the car from starting.
  11. Lex
    Lex Active Member
    Geelong Victoria
    VT Executive S1 V6 Auto Wagon
    Maybe engine earth leads?
  12. mark b12
    mark b12 New Member
    vr comodore
    i got that sorted it was a fuse,,i now have the lights ignition working but it not cranking now,,ive left the key in ignition for half hour see if this makes a difference,
  13. losh1971
    North Tas
    VR Ute V6
    Might be key sensor ring or NSS, or even ignition switch. Try jumping the solenoid on the starter to make sure there is not something going on there.
  14. mark b12
    mark b12 New Member
    vr comodore
    thanks all,,it seems to be th ignition,,i left the ignition on for half hour and it cranked over,,just recharging battery n checking everything I hope to start it this afternoon will let you know how I'm going
