VR odometer/tripmeter/speedo fail
Dunlop
68
Beechworth
1993 VR Commodore Acclaim
The odometer and tripmeter on my VR Acclaim (1993) stopped working after a 786 km trip recently. I followed the directions on a really good youtube video about replacing the tiny cog in the speedo which I found had a broken tooth, and replaced the instrument cluster. When I took the car for a drive though, I found that not only the odometer and tripmeter were still not working, but the speedo had stopped as well...About ten years Marvin put a very good post on this site on how he used his multimeter to detect a broken circuit on the rear pcb. I tried this with mine, but don't really know where to trace the wiring and exactly where to put the black probe of the meter to detect a break. All the other instruments work, so could anyone offer any suggestions? Thanks.
vs-lover
VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
I must admit that I have done a few odometers repairs over the past year and the only one that didn't work out was my sons car which after the job failed to function. I ended up simply changing the whole speed assembly within the cluster for another unit that had nearly the same amount of K's on it and that works fine. So from that the issue with my sons was something electrically failed within the assembly itself and not the actual cluster housing. BTW the speedo did function on the initial one both before and after I did the sun gear change.
Dunlop
68
Beechworth
Thanks for that...not everyone is an electronics wiz. I've since contacted several specialists to see if I can buy a used cluster - the last promising person is looking for one so maybe... Otherwise i might be able to buy one off ebay etc. Hassle that it might be some small issue like a tiny break...
Dunlop
68
Beechworth
Update on inoperative 1993 VR speedo. After I posted on May 10 this year about replacing the tiny cog in my speedo assembly and finding that the speedo no longer worked either, I sent the full cluster to Lonsdale st auto electrics in Dandenong after a referral. The tech found that the tiny tooth broken off the cog had fallen into the mechanism and had jammed up the speedo... If you replace this cog, I suggest you make sure nothing in the housing will fall out (assuming you still have the main cog out), turn the unit upside down and give it a shake to see if the tooth (or teeth) come out. If they don't, you might have to look into the mechanism to make sure broken teeth aren't jamming the mechanism.
When I put the cluster back in (carefully) and took the car for a drive, the speedo STILL wasn't working ("Oh no..."). Following a discussion with my mechanic who checked the sender unit on the trans, I decided to send the unit back. Unfortunately the tech was away sick, so I had to wait a week to get it back. Put it back in after he checked it and found it working, and it STILL didn't work... Not happy at all. Another check with the mechanic suggested taking it to the local auto electrician just up the street. After he checked it, he found the sender is working, but the speedo isn't - after I'd just spent some $180 on having it fixed.
The auto elec said that an instrument specialist he uses in Heidleberg said that these speedos can tend to give up in the end and the only real option is to buy another one. He's going to try to source one for me with a warranty. Car has done about 240,000 kms.
Ironically, after recently putting some Xcelplus and Engine Restorer into the oil, I found a significant improvement in fuel economy and an increase in power, but when I picked it up from the elecs and drove it off (engine nearly cold - cold night and morning), it now seems to be a bit sluggish in acceleration. Will put some more injector cleaner into the tank and just hope this solves that problem.
vs-lover
Yes aging electronics are the downfall of many of these types of things, thus why I simply changed the speedo itself and put it into the cluster housing. It works fine now but I'm starting to think that it's the wiring strap that connects the circuit board to the assembly that needs to be disturbed while doing the job and that it ends up breaking connection while we're in the process of repairing one part while another is now failing. Them's the breaks with aging items that are subjected to immense heat in the summertime and shivering cold during the winter.
