vr problem help plz
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by auz_tas12, Feb 28, 2012.
  1. auz_tas12
    auz_tas12 New Member
    brisbane
    vr 5 speed wagon
    ok my vr 5 speed wagon started playing up when u drive it its jurks carrys on like its starving for fuel and at round abouts or complet stop wich is dangerouse it has no throttle respons like u push the pedal its nufin like its bout to run outer fuel sometimes its stalls then starts back up.......then drives like a normale vr then does it again very embarrising sometimes but wen it plays up basically there no response to the throttle i push it rite down and up continously nufin..no response then after sitting on side road for few minutes i can finally take off im guessing air leak around throttle body or throttle body gasket sucking air if so would this cause sympton also wen playing up the engine light comes on and off this would happen if it had air leak where gasket is on throttle body? cheers guys hope i made sense any help would be very greatfull basically car is too dangerouse to drive and need help asap
  2. James39
    James39 Gave up on VL's
    Newcastle NSW
    1995 VS Acclaim & 1992 Holden Barina
  3. auz_tas12
    brisbane
    vr 5 speed wagon
    yer i will do that tommrow but was hoping some one mite know the answer
  4. VR38
    VR38 Well-Known Member
    VB SL/E
    Might know but code check will confirm, might be temp sensor for ecu.
  5. James39
    Newcastle NSW
    We would only be guessing and that would be pointless, doing an error check will help point you in the right direction.
  6. woteva
    woteva NEED 4 SPEED
    Adelaide S.A.
    Sounds like CAS. It will not usually show an error code.
  7. FstStig
    FstStig Diagnostician
    Central Coast, NSW
    2010 VE SV6
    I'm thinking more TPS, IACV or MAP sensor.
  8. auz_tas12
    brisbane
    vr 5 speed wagon
    i think found the problem the throttble body where throttle body gasket is is sucking air im guessing that would cause all th sysmtons lol
  9. FstStig
    Central Coast, NSW
    2010 VE SV6
    Yep, no throttle body gasket + Gap = More air into the intake before the MAP and IACV can take a reading.
  10. auz_tas12
    brisbane
    vr 5 speed wagon
    yer gunna pull it off tommrow put new gasket on hope all goes well lol cheers everyone shal let use know tommrow
  11. woteva
    woteva NEED 4 SPEED
    Adelaide S.A.
    Did you get it fixed ??
