HybridAero
- Jun 28, 2005
- 30
- 0
- 0
- Age
- 39
- VR Equipe
looks like no3 is running ok, not a problem as you suggest with that one
illd start with a new set of spark plugs, pretty cheap, $20 or so should get you 6 new plugs
then if this dosent make things much better, look at a new set of spark plug leads around $50
still haveing problems after that? illd check the coilpack, if you know someone with a engine the same thats running well, see if you can borrow there coil pack and fit it to yours and see if theres a differance
coil packs can die, as ive had a few issues with in te past with them
illd say that will cover a good 90% of the issues with a miss
you could try a compresion test after that if still dramas
or could be a blocked injector
do the same as i mentioned with the coilpack, but change the injectors with ones you know are ok
