hey guys, i was wondering if anyone had come across a vr that kept on blowing the EFI relay and why?? mine has blown two in a week and they are 23 bucks each so im over it..:bang: any help would be appreciated
Can you pop the cover on the relay and take a photo of the guts. Might give us an idea of whats happening. Are you getting the relay from holden or shops? Reason Im asking is that there are many different types of relay - and they all look identical with the exception of the circuit diagram on the top of the relay. If you arent getting the exact type relay it may be the incorrect relay causing the problem. If you are getting it from holden (relays from holden are normally priced fairly reasonable) they should be giving you the right one.
