Hi Muik. Sound like a block somewhere! It may be possible that your fuel filter may have some cr@p blocking it:bang: When the tank run's dry,the fuel pump tends to suck up all the cr@p at the bottom of the tank:bang: causing the strainer net on the bottom of fuel pump pick-up and fuel filter becoming blocked! Worth a try checking fuel filter for blockage maybe?
Once she's all back together, check fuel pressure. Remove hose from regulator to injector rail, at injector rail end, place hose into a small container to catch fuel, turn ignition on, DONT start, see if fuel really squirts out, alot of pressure should come through...
If no pressure, possible blocked pump or faulty regulator?
Good luck :thumbsup:
