VR Senator with LSx454
Discussion in 'VR - VS' started by VRSenator065, Apr 8, 2013.
Thread Status:
Not open for further replies.
  1. VRSenator065
    Gawler SA
    VR Senator LSx454
    Seems like it might be a bit engineer specific though, maybe worth asking yours before you do.
  2. NORTI
    NORTI Crazy VS lady
    Gen 2’s
    No worries, had a similar idea in mind. I haven't seen Ian since I was a kid, might have to have a chat.
  3. ari666
  4. VRSenator065
    Gawler SA
    VR Senator LSx454
    LOL, actually I agree with you, maybe a billet black one?
  5. ari666
  6. VRSenator065
    Gawler SA
    VR Senator LSx454
    PM sent :)
  7. NickVR
    NickVR Active Member
    Adelaide, SA
    VR Executive A4 V8
    Just some info on that and hoping this can be done too. A supplier that we deal with at work that does the changeover ABS modules brought up some good info which stuck in my mind. The Commodore ABS module is a common failing part. From what he said that these are the same as the falcon units. The Falcon units fail less in comparison though. The reason is how they are mounted on the car. On the Falcon they sit flat on top, but on the Commodore they sit on the front (sideways). This is the reason they fail more regularly, as they weren't designed to sit like that. So if possible see if you can mount it so the module sits on top like the Falcon's do as this may result in a lower failure rate. Not sure if will affect operation at all but just thought I'd throw that info out there. Especially if you plan to hide it.
    Sorry to hijack it. Anyway back to the awesome thread.
  8. VRSenator065
    Gawler SA
    VR Senator LSx454
    Thanks Nick, all good info. My engineer was quite definite about the height thing, to be perfectly honest I am not totally sure why from an actual functional point of view. I will say he is a very very good engineer, and so far hasn't suggested anything that didn't have a very sound reason behind it, he's not a "just do it my way" kind of guy. Btw, the way I have mounted my ABS is at 90 degrees to how it sits normally. So maybe out of luck by the sound of it I may end up with a little more reliability if I read what your saying correctly. Btw that's not a hijack, all useful info gladly accepted!!
  9. VRSenator065
    Gawler SA
    VR Senator LSx454
    So anybody know where I can get a nice billet black brake reservoir cover?
  10. immortality
    Sth Auck, NZ
  11. VRSenator065
    Gawler SA
    VR Senator LSx454
    Thanks, have sent them a query a couple of hours ago
  12. savage1987
    savage1987 Donating Member
    God damn, Bain's main video on their website hurt my brain so much. I guess you don't have to be able to spell to weld decently, but still, man.... come on.
  13. VRSenator065
    Gawler SA
    VR Senator LSx454
    OK, gotta say I have never noticed, but I am assuming its the, "there" instead of "they're". As you say, his welding is awesome :)
  14. ephect
    ephect Donating Member
    VS Acclaim V6
    I know last weekend was a busy one, if U get a chance this weekend :) much appreciated
  15. VRSenator065
    Gawler SA
    VR Senator LSx454
    ****, forgot all about that, should be able to tomorrow, I got the new fuel tank dummied up in position last night so I will be working around that area tomorrow, so will get some pics.
  16. Sokoza
    Sokoza Beep Beep
    QLD
    '92 VP GTS
    What! 7 days and no updates. I'm starting to get withdrawls.
  17. VRSenator065
    Gawler SA
    VR Senator LSx454
    Lol, been doing a lot on the fuel system, so not a huge amount to show, but heaps of bloody work, tbh I am sitting having a beer and bloody stuffed. Today routed the 5/8 hardline for the feed tomorrow hope to do the 1/2 return, made up a pair of bulkheads to switch from the hardline to the braid to tank, and up to engine. Came up pretty sweet but farking time consuming. Lesson for learners like me, should have done it when the engine, trans and rear sub frame was out but anyways. Bought a really nice Holley lift pump, working through building the pump system into the front of drop tank. Hopefully tomorrow avo may have a decent update.
  18. VRSenator065
    Gawler SA
    VR Senator LSx454
    Btw, I tried to take some shots but it doesn't really show anything coz its up on the hoist so the wheels are hanging down at bottom travel.
  19. Vs hsv manta
    Vs hsv manta Member
    Mackay
    Vs hsv manta
    Lol how did u go getting a 5/8 line up over the cradle ???
    Bet u got a couple scratches to touch up !!! Well I do anyway !!!
    Iv been doin myn in 1/2 inch ID well actually 16mm out side and my extractors have cats attached and come just past where the lines come into trans tunnel, it's a pain and carnt really be done in 1 piece so dropping cradle out to do them in 1 piece !!!
    Are doin weld on fittings or did u get the tube fittings to go from hard line to an style with the olives ???
    And did u manage to fit both lines from after trans tunnel along the factory spot ??? I'm trying but dam it becomes tight and will be hard to keep them separated so no rubbing occurs
  20. VRSenator065
    Gawler SA
    VR Senator LSx454
    Will post some pics tomorrow, but I am finishing the hard line at the back of the trans, then just going for there to a bulkhead on the firewall in Teflon braid. Yes was a bitch to work the 5/8 but in the end it's neat as, pretty much followed the factory path then made up a bulkhead above the drive shaft to terminate and go braid from there to the fuel tank. One day I want to make a genuine 1000HP so I am trying to do it once and build in capacity so I never have to touch it again. Never done one before though so I am learning as I go.
Thread Status:
